Manual series recording question | SatelliteGuys.US
lacubs
1,596
42
Erie, Pa
i got 2 Manual series recording but after a week, instead of saying the program name , it start saying "Manual:Title not Available" do you know how to fix this?
thanks , Mark
this been happen even when i did tried that , its just said Manual:Title not Available
because they don't have a run date, so, if when it show twice a day i need to canceled one program everyday
I think I can tell what you're trying to say.
Sounds like you're making too much work for yourself. What is the program? Recording it the normal way and deleting the extra shows (or having it only save 1 episode, if you watch it right away) seems A LOT easier than dealing with all this. I have never used the manual record because it doesn't tell you what it is.
thanks , Mark
I've found the easiest way to do this is go to upcoming shows and then select the ones you want. You'll have to do that twice a month, but it beats deleting show after show.
RAW not recording?
NBCSN showing up twice in guide
