Manual Timer - No Delete | SatelliteGuys.US
RT-Cat
"My person-well trained"
1,659
236
Cold, Cold,Michigan USA
Found something "odd" with a manual timer. As an example, set it for three hours and two minutes. The two minutes at the end to be sure of no cut off. Watch the recording later in the day after it has finished recording. When finished watching the recording shows no "delete" in the pop up screen. There is a "stop" command, but does nothing. I have found the "delete" shows up then next day. Any know reason why no delete?
Did you go to the Timers listing to see if it was listed and then try to delete it?
Horizontal green line at bottom of screen
722k Duo - OTA and Satellite to TV2
