Manually programming a DSR 922 | SatelliteGuys.US
wlong1136
7
LPTV is broadcasting on AMC-3 ku, Trans 4, DC II, V L-Band freq 1038.0, Sym 14.63, FEC 3/4
I have been tring for a week to program the signal but can't get the DSR 922 to light up , no DC sync.
Anybody out there have any suggestions. People at the station (LPTV) say their monitoring it up on a DSR 4200V unit at the station.
I always thought unless the channel was mapped into the reciever you can't get it
And according to Lyngsat it isnt mapped.....usually in the column where they list the audio pid they list the 4DTV channel in RED
If you scroll down on Lyngsat you'll see GPTV is in red at 640
Have you been trying to set up your 922 to use generics or are you just trying to change the tuning settings? The generics may or may not work, depending on the satellite signal. Good luck.
I was able to get it using the manual tuning on my 922.
PM me for the specific steps or move this to the "What's Up There?" section.
Pole length for 11 ft dish
Mounting Pole Indentation
