Marine - Latin Directv Venezuela to Colombia | SatelliteGuys.US
jwinzey
4
Bogota
Dear members:
I am in the Marine area, and actually have a Satellite TV antenna Intellian i3 (http://intelliantech.com/product/Pro...series.aspneed) with a GPS tracking system that works great for Direct TV in all of Venezuela. I need your advise in understanding, since I am moving to Cartagena, Colombia, if the same antenna will work. I am planning in contracting locally with Direct TV Colombia their receiver.
I have researched in Dish Pointer and it seems the distance in Cartagena (Distance: 36334km) is even closer than Venezuela (Distance: 36906km) for the 3C Satellite.
The area of use in Venezuela was Latitude: 10.1997° Longitude: -64.6367°, and in Colombia will be Latitude: 9.7199° Longitude: -75.8386°
I couldn´t see your link (indicates error 404 in I guess japanese charachters)
Below is a link for a Directv dish used in Colombia
ANTENA DIRECTV NUEVA COMPLETA - $ 10000.00 en MercadoLibre
It doesn´t indicate the size but it seems to be no larger than a 36 incher (90 cmts)
I would think there is not much diferrence on the satellite´s (I understand Galaxy 3C @ 95w)footprint between Colombia and Venezuela which are next to each other.
I checked on dishponter.com to see what dish size is recommended for the locations you indicate but I haven´t found that feature very reliable and rather often missleading, unfortunately it does not provide data for Venezuela (or I did something wrong) and it indicated 1.20 for Colombia.
Whole Home + Internet Hook up
Need a rcvr for our RV...best practices?
