Master reset code of HR54 Genie | SatelliteGuys.US
A master reset will wipe everything and make it as if it were brand new out of the box ....
Are you SURE this is what you want to do, as there are other options as well.
Menu/ Settings/ Reset Options /
At that point you have an Option to :
Restart this Recvr
Reset to Defaults
and
Reset Everywhere
I'm thinking that should say Reset Everything, anyways, THIS is where you go to go back to the beginning.
Follow the steps from there, you'll probably have to hit the - button at some point to confirm.
