Match Box Pro and My Theatre | SatelliteGuys.US
patbelcher
33
West Palm Beach, FL
Hello to all,
Has anyone had any success using the Matchbox Pro USB dvb box with My Theatre. My Theatre recognizes the box but does not detect any signal, and when scanning, it does not lock. Have tried different configuarations but no luck. Match Box works well with ProgDvb (except for the frequent freezing/lockup when channels are changed). Any help or advice is greatly appreciated.
Thanks,
Pat
Have you tried ProgDVB 5.14.08? Earlier versions had more of a problem with this. It's worth while to check his site once a month for new versions with fixes listd.When you install the new version it keeps all of your settngs. I use his BDA driver 878.
Lifetime Ultra LNB Voltage Problem
33,000 plus posts for Iceberg
