Does someone know the maximum numbers of timers on the ViP 922? I currently have a ViP 622 and I can only have 99 maximum timers. Thank you.
MattG@ DISH NETWORK said:I don't know if it's a typo, but the 922 doesn't show a number of events cap (which is 576 on the other VIP DVR's), only the 96 timers cap (which is the same as other VIP DVRs)
You can count events from the DRA page, if that still works.
DRA shows: a count of timers, scheduled and skipped. I assume the event count is the sum of scheduled and skipped.
I assume an event is created for every guide entry that matches a timer, so a timer for a daily program would have approximately 10 events.
What happens to events prior to the current time of day? Wouldn't those events be released to the pool so other timers could then include additional events? If event (re)scheduling occurs frequently (say a couple of times a day), how likely is it you would actually miss a program?
Or is the issue that if all the events are used up, you can't create new timers? Maybe that's the thing that should change: if the event pool is empty when a timer is created force rescheduling and take future events away from other timers to satisfy immediately pending events for the new timer.
Limited time offer
