Hi Guys -
I have the opportunity to use the old BUD at my office. It's been abandoned for at least 10 years. It would need to be completely re-wired as the original actuator cables are turning to dust. I won't be moving it, I can use it at it's current spot. The mesh looks good to me, I saw one maybe 1" dent from probably hail at some point. I'm wondering if I should look at swapping the LNB with something else? I took a bad picture of the LNB but I got the model number ACS-740. A little google-in and I see this is a Norsat LNB? Any thoughts on this? Also for actuator wiring I did some reading and see mixed reviews on AWG size. Could I get away with 18AWG sprinkler wire if I'm running between 100-150 feet?
Anyway the dish is branded Zenith - I did some reading and it seems these were Winegards? Looks like an 11' footer to me.
What should I do to the actuator before I try putting power back to it? Are they serviceable/need greased/cleaned?
Pics attached! Also pics of a KU they told me to take home if I wanted.
