Member's List? | SatelliteGuys.US
Member's List?
Not open for further replies.
raoul5788
Studebaker driver
Staff member
HERE TO HELP YOU!
33,085
18,359
Cheshire CT
Okay, I have looked and cannot find the list of Satelliteguys members! How do I get to it? Please don't just post a link, tell me where it is. Thanks!
That's a good question. I can't seem to find it either. I have the link.
I think it got to such a large size that Scott removed it or shut it off. It used to be a link at the top by the search.
You can search for a username using the advanced search under the search option.
Thanks Ramy, it should probably be in the quicklinks or something, but isn't.
Perhaps it will be fixed with the new software Scott is working on, upon his return from the Atlantic.
Scott has mentioned a couple of times that he removed it on purpose. There was a spamming incident via PM last year that prompted it. I just bookmarked the link since the feature is still active, just not the quick link.
Ah, that explains why it isn't available anymore, at least not easily. Thanks for the link, Ramy.
www.google-analytics.com
Server Work TONIGHT!
