Here's something that niggles at me, and maybe someone can help me out with their experiences. My main system is a Fortec 90/Merc II/Invacom QPH031 lnbf. Typically I blindscan several birds in the evening looking for new HD or 4:2:2 feeds ( maybe the find of my life, for example ). If I find a likely feed, chosen by a reasonably high symbol rate, I put that channel ( TP freq/polarity/SR into TSreader and try to acquire the video with tsreader and VLC.
It doesn't work that easily because my Merc II reported Symbol rates are always about 1% high. SR of 30000, for example , is reported as 30031. Tsreader doesn't lock on that 30031 signal. I've learned to live with this and automatically try a SR about 1% less than reported by the Merc II, and now I get a lock on the first or second try ( since 1% still leaves room for a little error ).
Question : Is it the Merc II, or is it the QPH-031 ? Does anyone with this combination have the same problem? Does anyone running the Merc II with this combination get the Symbol rates more exactly? Does anyone running the Merc II with a standard linear see this problem ? If I weren't retired and on a limited budget ( that's kind of a joke, you know), I suppose I'd just buy a decent standard linear and try it out.
Hope you can help.
Brent
Hope you can help.
Brent
