Micro(Mini)BUD / [COLD] testing with the Titanium C1-PLL | SatelliteGuys.US
northgeorgia
1,557
211
North GA
I'm excited about this. Got it on the dish now, but will probably switch it out in an hour or so -- rain showers gonna set in for several days. However, I did a normal blind scan [microHD] of all channels on 99W with my old WSI scalar kit and the Titanium C1-PLL. Results are an impressive 37 TV channels and 27 Radio Channels. This is on a WSI 90 inch dish (90x99). Not bad so far!
Yep I am very impressed with the C1-PLL.
It will be a few days before I can "play" with my microBUD again. As you know, when you get down to these 1 meter and smaller dish sizes, it's almost all experimental with tons of variables. I haven't quite found the sweet spot with the scalar yet. I like to use SatMex6 as my primary satellite with this project as it has a real stew of transmissions: DVB-S and S2, scrambled and ITC, FECs all over the place, occasional feeds, too -- ol' reliables and some surprises, too. As normal with this size dish, the time of day can also affect what you get. Sometimes I'd get about a dozen channels, and other times only three or so scanned in. On the other hand, I was able to receive Globovision from Venezuela, a new one for me.
A couple of the TV channels I first reported on 99W were interference from adjacent sats. Most weren't. I couldn't get GDMX or the CEA muxes (I have in the past, sometimes, with my other LNBF), most of the DVB-S2s, or a few other network feeds. But, I got most everything else just fine, including KCWY, usually touch and go with my DRO LNBF. I was also able to pull in a few new ones: Telesistema (pixelated) and Canal de Casa (perfect) out of Mexico. LESEA and the PR/VI mux booming as always.
Sorry, no NASA or anything on 105 (or even on 103), but NHK had the highest reading yet at a stable 70Q on 58W. I also believe Classic Arts Showcase (SD) was a new catch for me on 91W. When I'm not threatened by darkening skies, bitter cold air, torrential rain, or good Ku-band stuff in the coming days, I'll be able to adjust the scalar a bit more and will likely get some more interesting results (the reason I keep emphasizing this is because it is important. With my DRO LNBF, I could never get the 1/2 FEC NW Territory Legis. channel on 107.3 when I had the scalar flush with the end of the LNBF. Once I had pushed it to align with the first internal ring of the conical scalar, it came it just fine -- however, I lost several other channels on other sats when I did that). I also didn't even bother scanning the whole arc today -- just 2 hours of play. A 90 cm dish is what it is, and you can't get a gallon of limeade out of one key lime. But I think I can juice a few more drops out with this baby. I am already satisfied with its performance.
Proper skew for this LNBF is and always has been 12 or 6 O' Clock. ;)
S6000500.JPGOh, I think I know what you mean. Of course, the pin has to line up with no skew, straight up and down [with the other pin perpendicular] as you look inside the tube. But yes, I had to turn it into the opposite position that I usually put my DMSi BSC421 DRO LNBF in when using it on the microBUD. That is, the outside "boxy" casing, looking at the dish from the front, should be in the 4 o'clock position rather than the 8 o'clock position. Don't forget to slide the LNBF as far back as it can go in the holder (the end of the scalar should touch the holder). I didn't take photos of the Titanium. Pics are worth a thousand words :) Here is a photo of the BSC421 (ignore the alignment with the scalar...although I had good results with this configuration, I find lining the lnbf up with the first inner ring of the scalar is best). The lnb/box casing needed to be on the other side on the Titanium for the correct polarity.
1/12/14 Results on 90cm dish. 12 - 2 pm [clear-calm/55F/"flush with first scalar rim"] scan
*Note: All the following listings are individual channels that scanned in, whether scrambled or ITC, or blank data channels. Some channels were only receivable when moved off the satellite away from adjacent satellite interference, but were successfully traced and listed under their proper location. Some ITC channels had great reception, while others had a high level of interference. The totals listed at the bottom reflect individual channels, not transponders, which are significantly less.
55.5W Intelsat 805
TeleAmazonas mux $ch-1, ch-2 4025 H 5859 39Q
58W Intelsat 21
NHK mux - 5 channels (4040 H 26590) 50Q
2 channels English (one in HD)
2 channels Japanese (one in HD)
$Premium
r-Radio 1&2, Radio 3&4, Radio 5
$Travel and Living (2 ch) (3880 V 27688) 60Q
$Discovery Brazil (2 ch)
$Discovery Kids Br (2 ch)
$Discover Health (2 ch)
$LIV Brazil
$LIV Brazil Dig
$TLC Brazil
$TLC Brazil Dig
$Animal Planet Bra (2 ch)
$Civilization (ESP (2ch)
$Civilization (PRT (2ch)
$Civilization Eng/
$Civilization (SPN
$Science (ESP
$Science (PRT
$Science (ESP) Dig
$Science (PRT) Dig
$Science English/E
$Science (SPN) Cas
$Turbo (ESP
$Turbo (PRT
$Turbo (ESP) Digit
$Turbo (PRT) Digit
$Turbo English/Eng
$Turbo (SPN) Cast/
$IS-9(signal 1) d
$Turner mux (TCM, Space, Glitz, etc. 21 ch) 3921 H 27688 70Q
83W AMC 9
MMTV2 VIBE (Multimedios Mexico 2 hr delay) 3817 V 2879 25Q
91W Galaxy 17
Classic Arts Prim (4076 V 3000) 37Q
$Fox News (Fox mux 3820 V 30000) 70Q
$Atlantic
$Central
$Pacific
$NG Mundo
$Nat Geo
$FMC
$Fox News Dig
$Atlantic-Dig
$Central-Dig
$NG Mundo-Dig
$NG-Dig
$FMC Dig
$Speed
$FBN - Fox Business
$ALT
$Speed Dig
$Business Dig
$ALT Dig
r-$FMC CRN
ch-1, 2, 3 (TVT Montanna/Perry's Jewlry/Knives live ) 3937 V 3000 35Q
($)CW Plus East HD (CW mux 3720 H 28800) 5Q [NOW SCRAMBLED]
($)CW Plus Central HD
($)CW Plus Mtn HD
($)CW Plus Pac HD
($)CW Plus Regional
99W Galaxy 16
Lesea-1 (LESEA mux 4000 H 26400) 67Q
Lesea-2
Lesea-3
Lesea-4
Lesea-5
Lesea-6
r-Lesea muxes ([15 stations] Angel, Pluse, Qtones, future)
No Name (PR/VI mux: WVXF LWN 3848 H 15029) 65Q
No Name (WSJP LATV)
No Name (WVGN NBC)
No Name (WSJX Fox)
No Name (WPRU ABC)
No Name (blank-feeds)
CEA2 (CEA feeds Mexico) 3933 H 1562 58Q
$Pacific [3930 V 3679] 67Q
$News
$Sports
$Atlantic [3925 V 3679] 67Q
$News
$Sports
The Pentagon Channel 3900 V 28000 42Q
Scrambled channels TV: 12
Scrambled channels radio: 14
$RED CANAL 2 (Televisa mux 3881 H 30000) 70Q
$RED CANAL 5
$RED CANAL 9
$RED CANAL 2 HD
$RED CANAL 5 HD
$RED CANAL 9 HD
DL Service
KCWY13 (KCWY Casper,Wyo. 3776 H 3254) 39Q
Telesistema 1 TVS (Telesistema feeds) 3928 H 3125 46Q
Telesistema 2 (more Televisa feeds) 3904 H 3125 42Q
Auto 6MHz (Canal de Casa Leon, Mexico) 3938 H 1562 65Q
$GDMX 6-11 (GDMX feeds 3820 V 25998) 70Q
GDMX 6-3
GDMX 6-4
GDMX 6-5
GDMX 6-6
101W SES-1
Ch-1 (Gods Learning Channel 3710 V 4340) 7Q
107.3W Anik F1R
NWT Legislative (Northwest Territories, Canada) 3806 V 6500 21Q
NU Legislative (Nunavut Legs.) 3825 V 6500 0Q
111.1W Anik F2
SCN (City Saska.) 4158 V 9737 14Q
SLN (Saska. Leg. Net)
MMT
[radio: RCS map/RCS FLS -- no signal]
113W Satmex6
Ch-1 (AYM Sports Mexico) 3845 V 7016 49Q
Ch-2 [AYM Sports Mexico - behind 1 hr]
Telarity Encoded [Mayavision] (3834 V 1808) 30Q
TV Venezuela (Globovision) 4079 V 2918 30Q
TV-NL (3862 H 3199 TV NUEVO LEON XHMNL-28 Monterrey ) 10Q
$MEXICANAL (3854 V 5712) 39Q
CABLECOM
CANAL TRECE (TreceTV 3773 H 2875) 39Q
$AZ NOVELAS (Azteca Network MUX 3900 H 30000) 10Q
$AZTECA 13-2
$AZTECA 13-1
$AZTECA 7 PB (ITC)
$AZTECA 13PB
($)PROYECTO 40 PB (ITC)
$AZ MIX
$AZ NOTICIAS
GPO IMAGEN (Imagen Radio 3853 H 3254) 32Q
RCG Saltillo (XHRCG-7 3764 H 2933) 35Q
first_service (PueblaTV 3824 V 4200) 56Q
RTN (Radio Y Television de Nayarit) 3783 H 2666 44Q
Ch-1 (Hidalgo TV 3820 H 3254) 23Q
UdeGTV_C44 (Universidad de Guadalajara TV Canal 44) 3703 V 2221 49Q
DVB-Server (TV de Campeche 3709 V 3254) 37Q
Ch-3 [radio, but no signal] 3787 V 7017 49Q
TDT (TDT TV Tlaxcala 3864 H 2415) 0Q
116.8W SatMex8
$GeoSing((1-8) channels) [unknown ] 4023 H 3699 42Q
121W Galaxy 23
$BFTV USA 3889 H 13019 42Q
Fight Now
Mi Casa Broadcast
$Baby TV
123W Galaxy 18
$Outdoor Channel H 4175 H 20000 70Q
$Outdoor Channel S
$Outdoor Channel S
$TEST MPEG4 HD
$ (A&E mux: 8 channels) 4160 V 29270 56Q
125W Galaxy 14
TBN HD (TBN Mux 3720 H 26667) Q49
Spare
TBN_sd
TCC
JCTV
SOAC
Enlace
TBN_HD_Dolby
Spare_AC3
TBN_sd_AC3
TBN TCC_AC3
TBN JCTV_AC3
TBN SOAC_AC3
TBN Enlace_AC3
TBN Spare AC3
131W AMC 11
$AE West (A&E TV mux 3940 H 29269) 49Q
$Histry W SD
$AE EAST
$Hstry E SD
$THC en espanol
$Military History
$History International
Total channels:
Radio -- 38
Television -- 217
Vonwiese lower support bracket needed
Best LNB Setup
