GEOSATpro - MicroHD remote repair or replacement. | SatelliteGuys.US
GEOSATpro MicroHD remote repair or replacement.
Gray Hair
164
74
N WV
Mute button no longer works.
#1 button sluggish.
Up and down volune button sluggish, Left and right volume button still works find.
GeoSatPro.com doesn't list one, nor as SatelliteAV on Ebay.
What solutions have been found?
Found these two remotes, resembles the correct one, labelled a little different. Not marked microHD. GEOSATpro Remote Free S&H 4.G5 | eBay
GEOSATpro Remote TESTED! Works | eBay
I've taken mine apart (fairly easy) and cleaned the conductive contacts on the button overlay with a paper towel soaked in plain isopropyl alcohol. You can do the same for the circuit board, if it's got crud on it.
Don't rub too hard, and works perfectly. Then just snap it all back together.
Thanks guys, much appreciated. Please pardon the delay.
Radioguy41,
What kind of hoops do we need to jump through to make it happen!
Thanks,
Respectively,
John
