AZBOX - MiniME SG6100 | SatelliteGuys.US
AZBOX MiniME SG6100
danleeper80
31
Northeast PA
Hi all,
I got an azbox Minime NA Edition I've recently decided to connect it to my motor using USALS. I'ev entered the my coordinates and the motor works as expected but I'm getting aimed at the wrong sat. There's a few more settings such as move on 18V and Motor moving speed. I have the 18V enabled and the motor moving speed at default. I'm assuming I have a setting wrong anyone know what the SG6100 should be set as?
Guess there's no solution... Guess I'll need to connect the Manhattan rs1933 somewhere and just control it via remote extenders.
I would help if I could, but I do not own that receiver. Interesting that the guy that sells that receiver has read this but not responded.
Hi all,
On an existing properly aligned motorized system, if the motor moves when using USALS but to the wrong position then you need to issue the "Goto reference" command from the receiver's motor settings menu in order to move the motor to its center 0 position and recalibrate it.
When changing to a different receiver on an existing motorized USALS system, one should always first move the dish to reference 0 position before unplugging the existing receiver in order to ensure the new receiver remains synchronized with the motor. This is normally not an issue when first installing a USALS motor at it comes calibrated to 0 position from the factory.
OTHER GBox V3000: Delete Individual Stored Positions?
OTHER Visionsat firmware
