missing channels on ariza extreme? | SatelliteGuys.US
amc1
i gave my brother inlaw a ariza extreme . he is using it for amc4 the
christian channels but he is missing 2 channels,3abn and the hope channel? it looks if their is no signal on a couple transponders,was wondering if it needs to have the factory flash reinstalled? it was used for another purpose.but the thing is i had it hooked up here at my home i got all of the channels when i hooked it up panning some of the fta sats.:confused:
dont mean to bump this up,just wondering if anyone has anything else to add ? brother-inlaw is bugging the crap out of me.lol.i dont have a dish set up for amc4. i had it up just finding what what sattelite is where and see what channels are on them at the time. i
was only interested in g10r .
Is the LNB type matched the LNBF (standard / universal). Are just vertical or Horizontal transponders showing quality? Did you do a transponder scan or a power scan when adding the channels for AMC4?
Try doing a factory reset then set the LNBF type and perform a power scan.
She should have asked SatGuys U.S.
Plywood Dish Antenna
