Missing HD channels | SatelliteGuys.US
Missing HD channels
  • Thread starter Thread starter jmc3352
  • Start date Start date
  • Replies Replies 0
  • Views Views 839
jmc3352
4
ohio
I cannot get a tech here for 7-10 days (due to my rep having covid issues).
I am in a bar with 18 tv's. I have a slimline 5 dish coming into a Power amp then to a Polarity locker then split out to 2 SWM-16 units then to 8 port splitters then out to each tv that has its own Direct TV box. I am getting no signal to the even transponders on 103/110/119, with the odd ones in the 90's. The 13V input to 103/110/119 seems to be the problem. I swapped out the cable and the issue remains, so that is not the problem. I have replaced the LNB and done my best to check alignment. What else can I check?
Here are my readings:
103s
1-8 all n/a
9-16 n/a n/a n/a n/a n/a n/a 0 0
17-24 95 0 0 0 84 0 34 0
25-32 all n/a
103cb
96 0 93 0 91 0 92 0
92 0 90 0 92 0 n/a n/a
n/a n/a n/a n/a n/a n/a n/a n/a
103ca
95 0 95 0 95 0 95 0
95 0 95 0 94 0 92 0
92 0 94 0 91 0 94 0
99s
92 73 96 78 87 0 79 0
0 0 92 90 95 95 95 95
99cb
95 94 88 92 92 88 92
91 94 83 92 96 95 n/a n/a
99ca
93 94 94 95 93 95 91 94
91 95 89 94 88 94 86 95
119
n/a n/a n/a n/a n/a 0 96 0
95 0 96 0 96 0 96 0
101
98 96 99 98 96 97 96
98 97 96 100 98 97 96 97
99 0 96 100 98 97 97 96
98 100 96 0 99 100 97 97
