Missing RSN after switching packs | SatelliteGuys.US
kikenovic
355
Somewhere in time
Hi,
On Thursday I switched from AT250 to LatinoMax. After the switch, the first thing I noticed is the HD american channels remained on their classical mappings (Espn HD is 140, History is 120, etc) which, is awesome.
I lost the channels I was suppossed to loose (SCI, G4, etc) and I gained the latino channels on the 800's.
Everything seemed to be fine, until I tried to tune CSN Chicago (my RSN for Davenport, IA) about an hour ago. Channel 429 is not on the guide at all. I also checked in the 5400's and the 9000's but it's not there. I receive the Big Ten no problem.
I tried a rehit via the phone and resetting my receivers. Still no sign of CSN Chi.
As far as I remember, Latino Dos and Max include my local RSN(s).
That channel was working fine for me on Wednesday night (when I was still on AT250).
Maybe Latino Max is no longer eleigible for CSN Chi or there is a glitch on Dish's system.
Can an IRT member shed some light on this please. Thanks.
You could run a check switch test and force a guide re-download.That may get it to pop up.
You definitely should have regional sports channels. Please PM me your account information and I will look into this. If you run the check switch test, please advise your orbital locations. Thank you!
Thanks for the suggestion Teehar. I did the check switch, the guide redownloaded but still no CSN Chicago.
I forgot to mention I'm on the Eastern Arc.
I sent a PM to Mary with my acct info.
Check Switch Snafu
HTPC tuner cards.
