Mixed-up channels: BravoHD+ instead of StarzHD on channel 261 | SatelliteGuys.US
Ilya
XXI Century Explorer
Staff member
HERE TO HELP YOU!
33,055
21,599
NE OH
Some people are getting BravoHD+ instead of StarzHD on channel 261, or have some other channels mixed up (e.g., 204, 206, 226, 229, 261, 262, 301, and 305).
This is a polarity issue, that is usually caused by improper wiring, bad LNB or wrong type of diplexer. (No need to replace the STB: it won't help!)
I posted a detailed explanation of this problem in the following thread:
http://www.satelliteguys.us/showthread.php?t=20970
I hope this will help!
I had this problem, but its been fixed. When I received an upgraded OTA antenna, Channelmaster 4228, the installer forgot to remove the powered diplexor. this was causing polarity problems.
White DOT Phenomenon only on VOOM..???
Motorola manual for DSR 550-location??
