hazmat626 SatelliteGuys Pro Original poster Aug 24, 2006 207 83 Lake Jackson, Texas Mar 26, 2012 #1 Suddenly moca signal symbol appeared on screen. How do I get rid of it?
Scott Greczkowski Welcome HOME! Staff member HERE TO HELP YOU! Cutting Edge Sep 7, 2003 103,711 29,476 Newington, CT Mar 26, 2012 #2 Press the Blue Button Select Whole-Home Choose Display Settings Then choose disabled and click Save.
hazmat626 SatelliteGuys Pro Original poster Aug 24, 2006 207 83 Lake Jackson, Texas Mar 26, 2012 #3 Scott Greczkowski said: Press the Blue Button Select Whole-Home Choose Display Settings Then choose disabled and click Save. Click to expand... Got it thanks.
R rdinkel SatelliteGuys Pro Jul 13, 2004 1,678 3 Woodland Park, Colorado Mar 26, 2012 #4 If it suddenly appeared, you way want to first do a little checking to see if there is a loose connection before you disable the symbol.
hazmat626 SatelliteGuys Pro Original poster Aug 24, 2006 207 83 Lake Jackson, Texas Mar 26, 2012 #5 rdinkel said: If it suddenly appeared, you way want to first do a little checking to see if there is a loose connection before you disable the symbol. Click to expand... The wife fessed up. She was playing with the remote.
R rdinkel SatelliteGuys Pro Jul 13, 2004 1,678 3 Woodland Park, Colorado Mar 26, 2012 #6 Actually that is very good news! And, no, I did not suggest she was the loose connection......
HIFI Resident Psycho Pub Member / Supporter Lifetime Supporter May 9, 2007 9,128 340 surfin SATGUYS in a round room with padded walls Mar 26, 2012 #7 otisanybody said: The wife fessed up. She was playing with the remote. Click to expand... :behindsofa:
