Good afternoon. Happy New Year.
danristheman and
KE4EST that helped to find this topic.
This LNB, the range C. With its depolymer I experienced.At us, this LNB works well with frequencies, circular polarization-R and L.
And you have all satellites, C range, linear-V and H.
Inside the LNB, Alyano depolarizer shtirevoy.Stoyat rivets iron.
My friend from Western Ukraine designed better LNB than Yaliano. With water pipes and a plate-cross.
First a few photos of the LNB Alyno.
This modified LNB works on small Dish, 0.6-1.2 m, the opening angle is 70-90 degrees.
My friend Vitaly from Western Ukraine has passed here such a modified LNB. This plate is a cross, you can test it at yourself. To do it, I'll write below. With LNB, take out your native plate and put a new one. The result is excellent. Started with 5 photos.
The guys from Siberia, instead of the native plate, put glass. The thickness of the glass is 4 mm, the signal is slightly growing.Photo-11
To be continued.
