Thanks for the help so far! I've done a lot of reading, and of course the more I read the more questions I have...
So here goes:
1) do I need USALS or is DiseQ1.2 enough? If it's optional, what does it offer extra? I'll be going for a SG2100 motor.
2) what is the difference between standard and universal Ku LNBF?
3) within standard LNBFs, what is the difference between ASC321 and ASC321S? I'll use this on a Winegard DS-2076 dish.
4) does the Coship CD VB-5300B receiver have S-Video output? Does it have SPDIF (AC-3) digital output (or TosLink optical output)? It's hard if not impossible to find consistent information on this receiver... Some doc mentions it, some doesn't, some sites say that it's in the doc but not on the receiver, etc. Can anyone in the US who has this receiver send me an actual picture (not a schematic) of the back panel?
5) basically my preference goes to a receiver that has the following: S-Video output in addition to composite, SPDIF or TosLink Optical out, at least 1 CI slot, USALS support (if I need that - see question 1). In addition to the Coship 5300B, I've been looking at the Fortec 5100 Ultra but again I'm not sure what the US model actually has as far as back panel connections goes.
Basically if the Coship turns out to be a good choice, I'll get that together with the Winegard 30" dish (DS-2076), SG2100 motor, and whatever LNBF I need - should set me back about $380 without cables so within my budget
Thanks!
Chris.
So here goes:
Thanks!
Chris.
