More Precise Blind Scans | SatelliteGuys.US
cyberham
5,572
4,415
Chiba, JAPAN
The GeosatPro calls it Detailed Scan. The Openbox calls it Accurate Scan.
What exactly do these more precise scans do that a Blind Scan doesn't? Do they simply scan more slowly? Or do they seek signals buried in the noise with lower C/N? I've often wondered if the additional time to use these scans is worth it.
Sent from my SM-G950W using the SatelliteGuys app!
The timeout is increased to allow more time to analyze the transport stream.
This is why some transponder services are not reliably logged during a blind scan, but logged during a transponder scan which might be coded to allow a longer timeout.
Makes no difference on typical fat TPs, but enables service logging on other TPs. Only useful if it logs more services...
Reactions: N5XZS and c-spand
Ecoda 22khz Switch Failure ?
