More than one Sling Adapter?? | SatelliteGuys.US
blueoval4ever
31
I will be upgrading my 2 622s to 3 722s tomorrow. From what I have found from searching Sling Adapter is if you are watching it on a PC or any other remote device only one can view at the same time. Even the TV2 will not show as an output while watching remote.
Could you buy a second Sling adapter so you could watch two remote locations at the same time?
You mean to put them on different receivers? Sure. Many of us have multiple sling devices.
Right. My wife has control of our 722, and she is often recording two shows at a time. So, the SA attached isn't always usable. So, upgraded my 622 to a 922. Good remote access now. Also, I think the remote system is still pretty buggy, and the receivers seem to work better if they are not multitasking too much, as in recording and slinging...
Idiot CSR's
Dish Network 722k Duo Multiple Issues -- Looking for Advice
