Motor and Dish Elevations?? | SatelliteGuys.US
avenger
596
5
Slidell, Louisiana
I am sure that this is not a new topic but, I have looked around and could not find some information concerning my question. I finally received my Invacon dual LNB (Circular/Linear) and would like to use it. I am a bit confused on where to set the Elevation angles for the motor and the dish elevations, is the Elevation angle of the motor set to the same angle of elevation to my closest True South satellite that I am to view which happens to be Nimiq 1,3 or set to a 30 degrees angle?. I do not have a manual for the motor for it got wasted during Hurricane Katrina's deed. Any help is greatly appreciated and welcomed.
Thank You very much for your help.:confused:
Depends on where you are in the country and what kind of motor you are using! The motor is usually set to your LATITUDE.
We need more details :)
Thank You. I am using a SG2100 motor, and live in the deep South, 40 miles from New Orleans, Louisians. Zip code is 70458
Thanks again.
True South satellite = IA-8 @ 89ºw
Motor ELEVATION = 60º (One side of the motor is marked Elevation and the other side Latitude)
Dish Elelvation (on motor) = 25º
Code:
                       Slidell, LA 70458
         Latitude 30° 16.704'N Longitude 89° 46.272'W
                       Sat Name Sat Lng Az(t) Az(m)   El  Skew
                       Amos 1/2    4.0W  92.1  91.9 -5.0 -59.7
                Atlantic Bird 3    5.0W  92.6  92.4 -4.2 -59.6
                Nilesat 101/102    7.0W  93.7  93.4 -2.5 -59.5
     Telecom 2D/Atlantic Bird 2    8.0W  94.2  94.0 -1.6 -59.5
                     Express A3   11.0W  95.7  95.5  1.0 -59.2
                     Telstar 12   15.0W  97.8  97.6  4.4 -58.8
                   Intelsat 901   18.0W  99.4  99.2  7.0 -58.4
                          NSS 7   22.0W 101.6 101.4 10.5 -57.8
                   Intelsat 905   24.5W 103.1 102.9 12.7 -57.3
                   Intelsat 907   27.5W 104.8 104.6 15.3 -56.6
                  Hispasat 1C/D   30.0W 106.4 106.2 17.5 -56.0
                   Intelsat 801   31.5W 107.3 107.1 18.8 -55.5
                   Intelsat 903   34.5W 109.3 109.1 21.4 -54.6
                    AMC 12/T 11   37.5W 111.3 111.1 24.0 -53.6
                        NSS 806   40.5W 113.5 113.3 26.5 -52.4
                      Pas 3R/6B   43.0W 115.4 115.1 28.6 -51.3
                         Pas 1R   45.0W 116.9 116.7 30.3 -50.3
                   Intelsat 705   50.0W 121.2 121.0 34.4 -47.6
                   Intelsat 707   53.0W 124.0 123.8 36.8 -45.7
                   Intelsat 805   55.5W 126.5 126.3 38.8 -44.0
                          Pas 9   58.0W 129.1 128.9 40.6 -42.0
                       Amazonas   61.0W 132.6 132.3 42.8 -39.5
                     EchoStar 3   61.5W 133.2 132.9 43.2 -39.1
                      Rainbow 1   61.5W 133.2 132.9 43.2 -39.1
               Estrela do Sul 1   63.0W 135.0 134.8 44.2 -37.6
                   Brasilsat B2   65.0W 137.5 137.3 45.6 -35.7
                   Brasilsat B1   70.0W 144.5 144.3 48.6 -30.1
                       Nahuel 1   71.8W 147.2 147.0 49.6 -27.9
                      DirecTV 1   72.5W 148.3 148.1 50.0 -27.0
                          AMC 6   72.0W 147.6 147.3 49.7 -27.6
                          SBS 6   74.0W 150.7 150.5 50.7 -25.0
                     Echostar 4   77.0W 155.8 155.6 52.0 -20.7
                          AMC 5   79.0W 159.3 159.1 52.8 -17.7
                      Nimiq 2/3   82.0W 164.9 164.6 53.7 -13.0
                          AMC-9   83.0W 166.7 166.5 53.9 -11.4
                   Brasilsat B3   84.0W 168.7 168.5 54.1  -9.8
                          AMC 2   85.0W 170.6 170.4 54.3  -8.1
                          AMC 3   87.0W 174.5 174.3 54.6  -4.7
                           IA-8   89.0W 178.5 178.3 54.7  -1.3
                      Galaxy 11   91.0W 182.4 182.2 54.7   2.1
                     Nimiq 1/4i   91.0W 182.4 182.2 54.7   2.1
                   Brasilsat B4   92.0W 184.4 184.2 54.6   3.8
                           IA-6   93.0W 186.4 186.2 54.5   5.5
                      Galaxy 3C   95.0W 190.3 190.1 54.2   8.9
                           IA-5   97.0W 194.1 193.9 53.8  12.2
                      Galaxy 16   99.0W 197.9 197.6 53.3  15.4
                     Spaceway 2   99.2W 198.2 198.0 53.2  15.7
                DirecTV 1R/4S/8  101.0W 201.5 201.3 52.6  18.4
                          AMC 4  101.0W 201.5 201.3 52.6  18.4
                     Spaceway 1  103.0W 205.0 204.8 51.8  21.4
                          AMC 1  103.0W 205.0 204.8 51.8  21.4
                         AMC 15  105.0W 208.4 208.2 51.0  24.2
                      Anik F1/R  107.3W 212.1 211.9 49.8  27.3
                      DirecTV 5  109.5W 215.4 215.2 48.6  30.0
                EchoStar 6/8/10  110.0W 216.2 215.9 48.4  30.6
                        Anik F2  111.1W 217.8 217.5 47.7  31.9
                  Solidaridad 2  113.0W 220.4 220.2 46.6  34.0
                       SatMex 6  113.0W 220.4 220.2 46.6  34.0
                       SatMex 5  116.8W 225.3 225.1 44.0  37.9
                         AMC-16  119.0W 228.0 227.8 42.5  39.9
                     DirecTV 7s  119.0W 228.0 227.8 42.5  39.9
                     EchoStar 7  119.0W 228.0 227.8 42.5  39.9
          EchoStar 9/Telstar 13  121.0W 230.3 230.0 41.0  41.6
                     Galaxy 10R  123.0W 232.4 232.2 39.6  43.2
                      Galaxy 14  125.0W 234.5 234.3 38.0  44.7
                  Galaxy 13/H 1  127.0W 236.4 236.2 36.5  46.0
 Intelsat Americas 7/Echostar 5  129.0W 238.3 238.1 34.9  47.3
                         AMC 11  131.0W 240.1 239.9 33.2  48.5
                      Galaxy 15  133.0W 241.8 241.6 31.6  49.6
                         AMC 10  135.0W 243.4 243.2 29.9  50.6
                          AMC 7  137.0W 245.0 244.8 28.2  51.5
                          AMC 8  139.0W 246.5 246.3 26.6  52.4
                   EchoStar 1/2  148.0W 252.7 252.4 18.8  55.5
       Satellite Finder is (c) Copyright 2004, P. Lutus
Thank you for the information. Very interesting chart. How can I have or obtain a print out of the whole list that you gave me. I just tried to do it and it only gave a half page of the list.
Thank You
Avenger, I'm in Metairie. Set your SG-2100 to 30.1 on the LATITUDE scale (the scale on the left side of the motor bracket looking from behind it) and don't touch it again. Afterwards, only tweak your elevation on the dish mount itself.
Dish elevation for us is about 25, but don't always trust the dish elevation scale implicitly. You'll have to do some slight tweaking.
Our true south satellite is at 91w (there are a couple of satellites there, Nimiq 1 for the circular side of your LNBF and Galaxy 11 for the linear :) ) or 89w (IA-8)...
EDIT: Forgot that you're on the east side of the metro. You're probably closer to IA-8 at 89w...
Congratulations Sadoun on mag mention
time for a stupid question....
