Motor Connection | SatelliteGuys.US
Motor Connection
RT-Cat
"My person-well trained"
1,659
236
Cold, Cold,Michigan USA
Everytime I do a search, I end up with a headache. After looking at 25 or so out of 100+ answers and still no answer.....you get the idea. Searching must be a high skill that I do not have. So the motor question:
One cable out to the Ecoda switch.
That splits off to 2 four output diseqc switches. One is full.
The other has only 1 output in use.
Where in this set up would you place wires for controling a motor? Or how would you change this setup to work?
(spelling may be off on the switch, but you get the idea)
RT.
Ted,
Are all the dishes located in one area. If so I think you could go receiver---->motor---->encoda---->four port diesqc's---->lnb's
Yes, all together. Your line up looks good. I guess I was thinking about the hook up of something else and that made some confusion. The confused mind gets mixed up when the mix up causes more confusion. Thanks.
P.S. Watching some guys surfing at Hunting beach pier. Stand up in chest deep water. Late yesterday the seagulls were standing there and only got their feet wet. Those tides are really interesting.
Wednesday trip OK. Will Email later.
Hot-TV on 118C
1 5/8" pipe for 36" Ku dish
