Motor, Dish Angle | SatelliteGuys.US
Motor, Dish Angle
hoster
41
We are trying to get this new setup to work, we are using a Fortec 90 and there LNBF and a DiSEqC 1.2 H-H Motor.
The instruction I have been trying to follow here is confusing to us here.
--The RX is a Fortec Lifetime NA Classic
It says to set the motor el angle to EL/Lat = 43.1 Done
The one problem is the Dec it set it 30 degrees on the dish mount.
Do set it for 30- the Dec of 6.600 or ???
That is the part I don't under stand.
The LNBF does it set for 0 skew or ???
We are at 43.1 lat and 87.9 longitude
Some help here please.
Rich
What brand of motor do you have ?
(If its an SG2100 then the angles should be............
Motor elevation = 47º
Dish (on motor) elevation = 23º)
Thanks all I have it now and understand it, I got it to work just need to fine tune it yet all should be good to go.
ThNAKS
Rich
Update satellite database on receiver
Component Video Cables
