Motor for Hotdish 90? | SatelliteGuys.US
Blindowl1234
2,035
94
SouthWest Ohio
Any preferences on what motor to use for a Hotdish 90? There is a little tab on the mount that would have to be bent to allow use of a SG2100 etc...Looks like it's made for maybe a STAB motor?
Could I use a SG2100 without problem? Thanks Blind:)
Hotdish 90 can be used on a motor. Few folks have done it here
Hotdish 75 cannot do to the way the bracket is set up (tth top is sealed so you cant get a motor shaft from the top into it)
Thanks for the input guys. This is my first project (for my brother) outside of my dish farm. LOS issues yesterday as he has a very small yard with a two story house like his within 100 feet....after mounting a pole and no luck hitting 97w or 101w it's up to the steep roof next week, Blind
NBC MUX?
Nbc@99w no audio
