Motorhome Dish | SatelliteGuys.US
Motorhome Dish
  • Thread starter Thread starter Longgone
  • Start date Start date
  • Replies Replies 0
  • Views Views 1K
Longgone
2
Boise, ID
Hi,
I have a motorhome with a single LNB crank-up dish. Unfortunately, the dish doesn't seem to work any more. Do the LNB's "go bad" on these things? Is there a way to test it? I had a crimp in the coax & replaced it, but I'm not convinced that it works correctly.
If I try really, really hard, I can get a signal strength of 45-50, but it seems to "flash" between 45 and 0, and of course won't lock on. I'm wondering if I accidentally did something to the LNB when I was working on the wire.
Even if this is something beyond my level, is this something an installer can check?
ps (sorry I posted this here - I didn't see another place for it)
Prepaid Card question-Dish500
do I need Switch for 2 dish 500's for 61.5,119,110
