Motorized dish not moving? | SatelliteGuys.US
rufun2sun
iowa
I have a Pansat 2700 that powers the powermax motor with dish for KU band.
The pansat used to move the dish from inside the house, I stopped using it for a while and decided to see what's on. Now I can only move the dish manually by the button on the motor.
Is there a setting I missed after doing a restart?
Which program are you using to move the dish-USALS or Diseqc 1.2? You can look under the setup menu for any satellite you watch...to learn this. Might just need to center the motor and reset the receiver.
Openbox and streaming online
Starband Channel Master 74E Pick or Not
