Mount for dish | SatelliteGuys.US
Mount for dish
speedy1906
13
Is there a mount that can support a 30 inch Winegard and SG2100 motor. I want to move my dish to the top of my house and want to see if the mount that came with the dish can support it on the roof. If you feel it can't could you please suggest what I could use.
Thank you
I just use the mast that came with my 30" dish….been there for 3 years with the motor (SG2100)
If you put the dish/motor on a down sloping roof it should clear, depends of course on the pitch of the roof.
I am using a factory mount for a 33" dish, that consisted of a base plate and two short struts. I made two longer struts by hammering flat the ends of some 1/2" tubing bending them to 45 degrees and drilling holes in the ends. I screwed the ends of the struts to roof joists and mounted them part way up the mast tube.
Any Downside to Using Rain Shield?
Step by Step Newbie guide for Captiveworks updating!
