mounting block? | SatelliteGuys.US
mounting block?
i would do everthing i could to avoid mounting a dish on siding....is the roof or ground not an option?....if you MUST do it then i would mount a piece of plywood to the wall and give it a few coats of paint to protect it from rotting....then mount the dish to the plywood....
of course this all depends on how big of a dish we are talking about....im assuming you are talking about a smaller ku-band dish....
Thanks Mikey11. I've decided to mount it under my eave. Please see my new thread here.
http://www.satelliteguys.us/free-air-fta-discussion/265624-under-eave-mount.html#post2628357
Samsonic BS-8100 want to learn how to setup?
Manual entry of AC3 PID's on a Fortec
