mounting lnbf on Sami dish | SatelliteGuys.US
truckracer
4,338
352
Charleston wv
Can anyone tell me how the feedhorn assembly mounts on a 7.5 foot SAMI c-band dish. I am planning on buying a new one but I do not want to use a feedhorn that has to have a polorotor. I am using this dish for free to air only and will need to use a c-band lnbf that switches polarity with voltage (13-18VDC).
Does the feedhorn mount use a circular clamp or is it specially drilled for a bracket? I need to know before ordering and none of the websites that sell them seem to be able to answer my question.
The polorotor servo motor would be fine if I was using a 4dtv receiver but my free to air receiver have no provisions for polorotor control.
Thanks a bunch, trucker :)
