"Moved and the Ethernet Connection | SatelliteGuys.US
Hunter Mackenzie
81
2
I have a quick question I am sorry if this has been covered before......I have "moved" to a different local market to get those locals instead of where I am....(Girlfriend was a reporter at one of the moved stations) She has moved on to a different market which I can not get if I move again so I have just kept the moved locals......I currently do not have my 722 hooked up to the ethernet jack....if I connect the ethernet cable will the receiver know my location? and give me a problem keeping the moved locals?.....Thanks very much....
Not easy to locate
Ethernet otherwise know as the world wide web is just that world. It is not as easy to trace as the TV shows would like you to think. By the time your "reply" gets to E* it probably has gone thru more than one node or server system. So as the other to said hook it up.
HD locals?
HD picture quality worsening?
