Moved satellite to brothers house. One poll was plum used smart box to find satellite. | SatelliteGuys.US
Z_finigan
31
12
Florida
I let my brother use my Orby satellite. I use a 10 foot satellite for my Orby.
But I can say. If you have the skew set and the elevation set. All you have to do is turn it slowly. And it will come right in.
So anyone having a problem. Use a satellite finder. Find the satellite. Then fine Tue it. It's easy. I have found it with an 18 inch dish before.
Ok my question is how do you set skew on the 18 inch dish or did 18 inch dish have skew setting
