Mover's Connection with DECA... and "Internet connection kit?" | SatelliteGuys.US
kanderna
SatelliteGuys Guru
142
6
Hi all -
Just got off the phone with D*, to sign up for Mover's Connection. Asked for DECA, and they'll hook that up to as part of the install.
The rep asked if I wanted the "internet connection kit." I asked him what that was and his response was something to the effect of "...you get internet from us and it allows you to access D* on Demand..." He kept telling me they were the service provider, and he just wasn't getting it, so I said sure. What the heck is this?
So they'll be moving my 2 HR20-700s and 2 HR20-100s (replacements for 2 -700s that went bad in the past 4 mo... wish I would've gotten different models)... any common problems that the installer might run into doing the install that we should watch for?
Looking through the forums I've seen the numerous pics of installations... I'm overwhelmed! :yikes
Internet connection kit allows MRV and VOD at the same time. If you hook up ethernet cable to get VOD it will disable the DECA.
Golf, Tennis, Nascar channels "compliments of DTV"
Channel change from another room possible?
