- Sep 9, 2003
- 12,362
- 2,080
I don't know how many times I have had DISH out since i became a sub in 99. Every time it has been because of switch failure. How can i convince them to move it indoors and out of the elements.
Geronimo said:I don't know how many times I have had DISH out since i became a sub in 99. Every time it has been because of switch failure. How can i convince them to move it indoors and out of the elements.
mikethedishguy said:Since you are a customer from 99 and have had had many problems I think it is safe to assume that you have a SW64. If this switch is not installed correctly it will fail often. Check to see if all your lines are properly grounded. If it is moved off the roof remember that that switch will need 6 lines run from the dishes to the sw64. The 6 lines is most likly the cause of the reluctence of the tech to move the sw64 off the roof. It is my oppinion that the prime cause of the failure is heat warming the switch then when it is rained on the cooling contracts the air in the sw64 causing water to be drawn into the switch through the conections. Because the space in the SW64 is so large the vacume created is significant.
If you have a sw44 or a dp34 there is no reason to leave them on the roof they only need 4 lines.
you do it yourself, if own the equipment, just move the switches indoors yourself.Geronimo said:Again how do I convince them to put it in indoors.
BrettTRay said:Make you put a ground block with #10 ground wire from ground block to ground rod BEFORE the switch. Also make sure there is a #18 messenger/ground wire attached to the dish and to the ground block.
mikethedishguy said:Check to see if all your lines are properly grounded.
LER said:If it is in fact a SW64, see if you can convince them since you've been through a bunch of switchs to go to DP LNB's and Switches.
I went through 4-5 SW64's and finally convinced them to do the DP stuff, and had no more issues. This was when I was back in Garland.
LER
Mike500 said:You can always place the switch in a box. As long as the cables enter and exit trough the bottom, the switch is protected from the weather.
Limited time offer
