Moving back to Nebraska | SatelliteGuys.US
jb2011
3
Canada
I may be moving back to Nebraska again and have Shaw Cable right now. I am thinking about looking into Shaw Direct to have over the next year, then just take it with me and install it back in the States if we move back with my billing address changing to my parents.
Is there any advice before I would do this on which satellite to get from Shaw Direct and what I should do to ensure a smooth transition?
The other option would be to go with Bell. Any thoughts about that, too? I see some complaints about Bell though...
if you want HD channels, shaw direct is the better way to go, as the footprint for Bell HD doesn't extend very far into the US.
If do go with Shaw Direct, you should get the 75 cm dish They will liklye send you the 60 cm dish, but you can easily get the 75 cm on craigslist, kijiji, or ebay
