First, SatelliteGuys rocks! I am a new member here, but have perused the forums before and found lots of good info. I have searched around a bit and am pretty sure I have the answers to my questions, but would like some confirmation as some of the threads are either old or went very off-topic
Became a Dish subscriber about 5 years ago. When the install took place they mounted the antenna (Dish 500, I think, I know it has 3 horns on it) on the roof, shooting over the top of a tree. Needless to say 5 years later it is now shooting through the top of the tree... Last year we jacked our house up to put a new basement underneath and raised the house by about 2.5', but I still run into signal loss when it is really windy/rainy and the tree has leaves. Yeah, I know, raising the house is the expensive way to get a better line of sight...
Anyway, we are about to do the final grading and I want to move the antenna to a pole-mount with a clear line of sight, and to make sure I am somewhat future-proofed. Currently I am SD only with a pair of 322's ran through a DP34, but will eventually go to HD in the future. The 322's are in a central place in the house, with coax running to each of the TVs and using UHF remotes.
. Thanks in advance.
- I know I need to use direct bury RG6 between the antenna and the receivers. I thought I read someplace that you should not use direct bury coax indoors as the "flooding medium" can wick out of the coax at the switch/receiver due to the difference in indoor/outdoor temps or something like that, or maybe it applied to having the cable exposed outside and not buried. Just wanting to get an answer on that, or find out if I am remembering incorrectly. If I can use direct bury inside, I am going to buy 1000' and redo all the coax runs since the basement is currently not finished, many of them are patched together, and I have access to everything.
- When I was hooking the receivers back up after setting the house back on the foundation I ran into some problems with getting all three satellites. In talking with a Dishnetwork rep, they told me that I only needed two of them, not all three. They may have mentioned that was just for the SD package I have, but my memory fails me. Finally the question, should I go ahead and make 3 coax runs to the antenna like there is now, or just two if the third is not needed for HD in the future?
