Check the LIST on the drop down menu on this website and generate a list of the three satellites for eastern arc 77/72.7/61.5. They would be under subscription list. Check and see where your locals are , if they are on eastern arc and whether they are on conus (nation wide reception) or spotbeam(narrow beam for that city). IF you are within about 90-100 miles from the actual city where the spotbeam is located, you should be able to receive them.
