Moving up to outdoor antenna - question? | SatelliteGuys.US
dschribs
20
I bought this yesterday and it actually worked prety good..
http://www.radioshack.com/product/i...1&origkw=antenna&kw=antenna&parentPage=search
Not great, as I kpet loosing signal here and there...but it worked ok. From 1 - 10, I give it a 7. It was right near the TV, they only give you a 6' cord at about street level. CBS was about a level 80. Fox (which I want the most) was about a 65 or so.
I'm going to up grade to an outdoor Winegard Batwing. Given that I got pretty good signals from the indoor antenna, I should do MUCH better with the outdoor antenna correct?
FYI - Antenna web says I'm 12 miles from the farthest local station antenna and that I need a YELLOW antenna.
the batwings are terrible performers. take more down then put up.
I just installed a R/S U75 at my home to receive a station to my rear with a jointenna.
I started with a batwing cause I had several lying around, then the double bowtie, then finally settled with the u75. I have trees behind me and when the wind blew, the signal was all over the place with the other 2...not with the U75.
I am not one for r/s stuff but that antenna works damn good and easy to mount.
I mounted the antenna on the j mount the double bow tie was mounted on.
I just got this one http://www.radioshack.com/product/i...057.2032187.2032189.2032205&parentPage=family
and it works GREAT outdoors. CBS is 97%, most are in the 70's. I picked up 15 different channels.
Wbbm Cbs 2 Chicago
Tower Distance
