'Moving' | SatelliteGuys.US
'Moving'
Wesro
273
Eufaula, Alabama
Sorry for this guys I searched and couldn't fine the answers I needed.
I have a 'friend' that is 'moving' to Atlanta from Alabama. He has two quick questions.
1. This 'friend' has a land line hooked to his HR20 for the CallerID. The land line is VoIP through the cable company. Is this going to be a problem with it calling out from an Alabama area code since he 'moved' to Atlanta?
2. There is going to be a time difference, the new address will be in the Eastern time zone and my 'friend' is in the Central time zone. I know he can manually change the time back but is there anything about the time zones I need to know that could cause problems?
The phone isn't an issue as long as it is the number that is on that directv account.
Actually, I don't think you can manually change the time on newer receivers, the time is tied to the zip code of the service address. Either way, it will not cause problems, just the guide will reflect the time zone it expects to be in.
Installer said I can't get DTV Signal but he can pirate NFL Signal?
Loss and then sudden return of Sat 2 signal ?
