I called and told them I already had a dish at the new location and they still insisted on sending a service man to check it out, is their anyway around this?
From the little that I've read in the past couple years if the account is on the AT&T system they require a truck roll to change address. If on the old system you may be able to get someone to do it. I've not read of anyone 'moving' once their account was transitioned to AT&T.
If they insist to send out a tech, go ahead and allow it.
The tech will call you before they come out. Tell the tech the house you moved Into already had Directv and you just plugged in your equipment and it worked.
Ask the tech to close out the work order, so he can get paid and you didn’t waste his time coming out. Be cool with the guy, say you used to work for Directv
If the tech reads between the lines, he will close it out as completed and get paid.
