GEOSATpro - MP4 playback strangeness | SatelliteGuys.US
GEOSATpro MP4 playback strangeness
rzg00
22
California
Most of my MP4s play back perfectly on the MicroHD however, I have one which starts playing a minute or so from the end. I can navigate back to chapter 1 and it plays just fine. It plays correctly from the start on my PC with VLC.
How might I determine if this is a encoding or decoding problem?
This occurs with today's firmware release (GSPMHD_0.19_01312013), and its immediate predecessor. If Brian would like a copy of the file I can put it where he can download it.
File details:
Format : MPEG-4
Format profile : Base Media
Codec ID : isom
File size : 167 MiB
Duration : 29mn 15s
Overall bit rate mode : Constant
Overall bit rate : 798 Kbps
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : Main@L3.0
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Duration : 29mn 15s
Bit rate mode : Constant
Bit rate : 700 Kbps
Width : 640 pixels
Height : 360 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 25.000 fps
Standard : PAL
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.122
Stream size : 146 MiB (87%)
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : HE-AAC / LC
Codec ID : 40
Duration : 29mn 15s
Bit rate : 96.0 Kbps
Channel(s) : 2 channels
Channel positions : Front: L R
Sampling rate : 48.0 KHz / 24.0 KHz
Compression mode : Lossy
Stream size : 19.8 MiB (12%)
Since this is a single file playback problem, we wont be looking for firmware issues. If there are multiple files with the same issue, we will look at the files.
Look at any errors with software like TS Doctor to see if there are any file errors. Maybe try rebuilding the file or changing the format.
Other members might have testing or software suggestions.
GEOSATpro microHD updating
AZBOX AzBox miniMe American edition version 1.20 firmware
