MRV struggles | SatelliteGuys.US
MRV struggles
CFilkins
59
Hi, guys...
So, a while back I started d/l'ing the CE firmware to my bedroom receiver, and left the main living room reciever on the NR. Well, last month, with the new NR rollout, both boxes were updated to the NR. Since then, I've downloaded the last couple of CE rollouts (including this past weeks) to the bedroom, as I had before, and I cannot get MRV working at all. I've done the keyword...I've rebooted both boxes...and I hit the "list" button and the local playlist comes up...that's it.
Am I missing something simple? Both boxes are hardwired into my home network.
Chris
First, test your network connection.
Secondly, IMO, there's a general consensus that a restart is required to get MRV server going; although sometimes a system test will jump start it if was working and later quit. Try cycling MRV off/on (you can use MISC. Options to turn it off but k/w search MRVCLIENTON to turn it on is still prescribed in CE notes) then keyword search IAMANEDGECUTTER again prior to restart.
Not sure about this but you may have to k/w search MRVCLIENTON & IAMANEDGECUTTER then restart your other NR receiver as well but I would try the CE server first.
The new CE's for the H2X models require the current CE on the HR2x units too. This happened about two or more CE's ago.
That's what I was afraid of...looks like I'll have to wait and hope for a new CE this weekend, and try to install it on both receivers to see if that takes care of it...of course, I'm running a pair of HR22's, but that could be the issue...
Chris
Chris
I agree you now need CE on both HR22's. I have two HR22's and until this last CE, the MRV Server in the B/R wasn't as reliable as the one in L/R. (Server would go down but continue to accept remote views from L/R but not allow the L/R to remotely view w/o intervention). This last CE had some problems with To Do List and in my case it froze both HR22's while in Standby overnight.
I'm hoping the next CE will address these issues and still be stable for MRV. The video splats are still there but it's not so annoying as long as it doesn't effect the audio and nothing is really missed.
Nice switch for someone looking to hardwire their mrv setup
MRV observations
