Mtvhd ? | SatelliteGuys.US
Mtvhd ?
greaser00
22
Why hasn't MTVHD played any videos in High Definition? I noticed that some videos are shot in wide screen with the bars above and below. Are they going to play any videos in High-Def soon?
Aspect ratios, so you mean letterboxing and pillar boxing.
Being SD or HD is about resolution, not the program's aspect ratio.
You can have letterboxed HD and SD presentations.
I think I may be able to speak on this somewhat. I work in post production in Nashville and we do a ton of country music videos that air on CMT, which is operated under the MTV Networks. Even though we do alot of HD work, I am still amazed at how few videos are still only done in SD. Now I know the budgets for country videos are less than Rock/R&B, so that might explain it some, but that is probably why there isn't alot of true HD videos on MTVHD because they aren't being supplied. just a guess.
The reason why you haven't seen HD videos on MTVHD is because they are not in HD yet. While the channel is there, Directv put that channel there as a place holder until they are able to broadcast in hd. Dont get MTV HD confused with MHD. Both channels are from MTV they are two separate channels.
Coax Run Question
what is OTA
