Multi Channel View | SatelliteGuys.US
Multi Channel View
Hock
26
Fort Worth, TX
On the 722, during the Olympics and other events, you could see six channels at once and switch to each by using the dish button. Anyone find it on the hopper? The multi recall feature is good, but I want to see what is one each before switching.
garys said:
Dish Interactive Home button is on bottom right corner of your remote. It works on the 722, not sure if Hopper has this or not.
The button takes you to the on demand menu with the 922 and I believe it's the same for the hopper.
Sent from my phone using SatelliteGuys sweet app
Who knows if Dish has any plans to support the whole DishHome portal beyond the legacy boxes. It is so SLOW to use and cumbersom, AND the mux channels are in STANDARD DEF, and take you to the SD channels. I stopped using DishHome a long, long time ago.
Ironically, the weather overlay on the 721 was my ABSOLUTE FAVORITE and we used it everyday, multiple times a day. Why didn't Dish keep this USEFUL and EASY feature without one ever having to leave the channel they are tuned to. I know NO ONE who uses DishHome, and it is because it takes you away from what you are watching, takes way too long to load and to long to get back where you were and often caused the box to reboot. We need WIDGETS!
Change output on Joey?
EPG Remaps
