multi lnb homemade bracket | SatelliteGuys.US
danristheman
3,146
1,142
85w
I am trying to make an lnb bracket for my slimline dish I am going to mount 3 to 4 superdish lnb's on to it. My question is do I have to make an arch bracket to have the lnbs at the focal point or can I use a straight piece of metal and mount the lnbs on to them in front of the dish?
Dan Rose
i used conduit hangers / pipe hangers and used 1/2 conduit in it so i could adjust them , if its a small dish then probably straight .
its been like a couple of years ago i posted pictures of it ...
Straight would be the easiest to make and would be ok to use. Make sure that you make in a way that you can adjust the LNB and / or bracket.
Elusive NBCs on AMC1
How to point a winegard Ds-2076
