Multi-Satellite Blind Scan Settings | SatelliteGuys.US
Stevemo
45
Canada
I am not sure if this a bug or an intended feature but I found that the Multi-Satellite polarity setting is not global through the antenna settings like the "Detail Scan" is. I had 97W set to V only (I do not know why) and when I did a batch scan of the satellites I only ended up with about 150 TV channels instead of 300. Eventually I noticed the issue when scrolling through the antenna settings, I changed the polarity to Auto on 97W, and then rescanned everything and it all worked out.
Steve
The assignable polarity on individual satellites was intended to be for users with assigned single polarity configurations or when satellites only have services on one polarity. It is not a bug, but certainly could be viewed as one... as you have pointed out.
I will discuss with the team to see if the Multi-Satellite Polarity could be configured in a way to be selectable to allow an override of the settings assigned in the satellite set-up menu. Initially, I would say not possible.
Transponder issue.
Azbox power supply fuse
