Multi-sports pack only active on one receiver | SatelliteGuys.US
rockymtnhigh
Hardly Normal
30,520
1,161
Normal, IL
Ok, I added the multi-sports pack today, and it has showed up on the acct's primary receiver (622), but does not appear in the channel listings for the 722; have done a check-switch, but none of those channels show up.
Suspecting this will require contacting tech support, but before dealing with them, I figured I'd ask here first. Any ideas? DO I need to do a hard-reboot?
I would try a hard reboot just to see but that is odd that the channels only show up on one.
Do you have all the other channels on the 722?
I purchased the pack on the internet about a week ago and it showed up on my vip612 in about 20 minutes and on the vip211 an hour or so later.
YES, the 722 has everything EXCEPT the Multi-sport channels in the 400-range.
I'll reboot and see what it does.
Its been about 5 hours, but I suspect if the re-boot doesn't work, that I will wait until tomorrow to see if they show up.
Rocky
Sometimes those can take a little but to show up on the secondary receivers. I know when I've added them before they can take a while but should have been up before 5 hours (an hour maybe)
Rocky
That is what I would figure. I think I will use the chat feature and contact tech support.
I did a reboot and it didn'tdo anything.
Case solved; He sent a new signal to the receiver; we did a check switch, and its working. I figured it was something weird like that.
Been considering the multi-sport pack. How about sharing how you like or dislike it? Thanks.
Can't tell yet; all the RSNs show up, but none of the professional games are available; the college stuff is though. Maybe someday Dish will run full-time RSNs. Maybe. :) But I am curious how much is available on a Saturday; plenty of College Basketball; hopefully some good options on it.
All out of market pro sports are blacked out but there is a fair amount of college games on there
I use to get it for college hockey games :)
IMHO if you like college sports it is a good deal especially during basketball season. I am considering canceling mine after basketball until basketball season again. Virtually every pro sport out of market is blacked out even year old reruns-- go figure.
losing another channel???
OK, just switched over to...........
