multi-switch? | SatelliteGuys.US
multi-switch?
Rufus_74
SatelliteGuys Guru
120
I have been away from this forum for a while, but now i'm ready to get back into the world of FTA. Anyway, I needed some advice regarding what type of multi-switch I could use with my system. I have 3 FTA receivers I would like to send the signal from my dish to the receivers. will a 3X4 switch work with a standard or universal lnb? I am insure as to what type of switch to use. any advice would be greatly appreciated.
thanks
rufus
a 3x4 switch will work but the LNB needs to be a dual output...either a standard or universal will work
I have a 3x4 multiswitch on a dish aimed at G10
lnb output 1-----13v input on 3x4 switch
lnb output 2-----18v input on 3x4 switch
running 3 recievers off said switch
OK , I'm all set up w/ fta. Questions:
cable
