Multi-switch | SatelliteGuys.US
Multi-switch
cybok0
12,786
39
Sha Ka Ree.
Can anyone tell me if you have cables coming into the house from a multi-switch, can you add another multi-switch from those cables coming in or do have to run the cables from the original multi-switch?
I want to add a second dvr (R15) to my living room tv with my Directivo, and I don't want to drill anymore holes if I don't have to.
I was thinking to take the cables from my Directivo add a multi-switch and then I'll have 4 cables.
Thanks for any help.
It should work as long as you are not using HD and you have the right Mulit-switch
Not a splitter.
2 cables should give you 4 out to 2 boxes.
Directv Credit $100.01
Any D10-200s or D-10-300s updated??
